Problems: 2005fpw and Xbox 360
ModBoyzz
Hey guys,
I just finished buying the HD-Vga cables for the xbox 360, in order to hook it up to my 2005Fpw.
For some reason the colors look all washed out. Its horrible. I verified that the display settings were correct. Its running at 720p (1280x720) .
However, when I hook up my Pc the colors are perfectly fine.
Has anyone else encountered this issue? :(
1280x720 looks very washed out on the 2005fpw. What you need to is set the resolution to 1280x768. Then go to image settings -> scaling. Set the scaling to aspect.
