Problem
crazyvato
my computer will post check my drives and everything, then it goes to the next thing which it says veryifing dmi data pool if i remember right. Verifying DMI data pool......... Update Success and then it restarts it does this over and over again (reposts)
I recently bought a new moniter and memory. I had to remove the stick of memory because it kept crashing my system. this is an abit IC7 mobo with the hardware down below
Just to be sure, you're not overclocking the memory yet, right?
Also, you mentioned that you had to remove a stick of memory, does that mean you put the old memory back in? Or you put two sticks of new memory in and had to take one stick out?
In either case, ensure that the memory has the correct settings (speed, timing and voltage) in your bios. I'd also run Memtest to confirm the RAM is working properly.
