I reinstalled a fresh copy of xp, and my sennheiser USB headset was working fine. I installed the beta drivers for the audigy 2 ZS and the headset still worked fine.
The sound comming from the speakers was a little too deep so I installed the normal full version of creative's driver suite and programs. The headset now has a horrible distortive click/buzz/scratchiness going on. I uninstalled all the drivers, even disabled the hardware in device manager and I still had the same problem.
Then I did everthing I just mentioned all over again ((worked after clean install, etc) and I'm back to the same problem. How come after a clean install the headset works and after the regular creative drivers are installed it screws up and uninstalling/disabling doens't help?
I need the headset to work as USB so I can use it only for vent while the games come out through the speakers.
Specs are in Sig
Please help =/
Edit:
Ok I tried reinstalling windows but this time without the sound blaster....still having the same problem when using the onboard sound card. The headset works fine on my laptop though.
Here we got with yet another reinstallation
Specs are in Sig
Please help =/
Edit:
