Hello,
I recently bought an Intel D865GBF, and I'm trying to connect two fans with extra-line for tachometer, but no success. I've tested the fans (Nidec Beta V, TA300DC, model M33406-33) directly to the power supply (only GND and 12V) and they works. I've tested the voltage at mobo's fan connectors and they read 11V (which is ok following the fan specs). Also, I've checked the connector matches the fan's lines order, though I know it should be pretty standard.
But no success! the fans does not work when they are connected to the mobo, and the BIOS does not appear to have any option to turn them on/off.
Any ideas??
10x
Any ideas??
10x
