Problem with speakers
krislim
Hi i got speakers like a week ago and i loved them it was very strong and everything was great. But today i played them again and its seems alot less powerful. For example the subwoofer sounds way weeker and the speakers arent as loud. My speakers are:
http://www.newegg.com/Product/Product.asp?Item=N82E16836121120
My settings are:
Effect:6ch direct
subwoofer:5 bars
center:7 bars
surround:9 bars
and volume i always put at 3 bars.
Somebody please help me
What are these hooked up to? A computer? You sure you didnt change any settings in Windows?
I had a problem like that with my Kenwood, turned out I had one channel shorted (speaker wires had been pulled out of the box, wires were crossed, laying on the floor)... amazing the damn thing still worked for the entire day without going up in smoke :eek:.
Unhook the speaker system from your computer and plug it into other things such as your vcr/dvd player, cd player, tape deck etc. If it still sounds weak, and your sure your not deaf from 'enjoying' it earlier, call or email logitec and see if they can offer any advice. Best most of us at [H] can do is fart around and give you general advice, and argue over the details.
It could simply be your computer, double-check the settings in windows by double-clicking on the picture of the speaker on your system tray, should bring up the volume controls. Once on my pc, some tard (younger sibling) cranked Wave all the way down to practically nothing, because he couldnt figure out how to turn down the volume on my old amplifier. Took me dang near 5 hours to figure out what the problem was :(.
haha thx for the advice guys i dont think i changed anything on the computer. It might be because i got used to the sound im not sure because now i turn the volume louder and the subwoofer sounds fine but im not sure.
and bob u mean that the wires came off from the back? because i just recently pulled my subwoofer further away from other wires and i pulled the rear speaker sorta hard but the speaker is screwed on the wall so its sorta hard to tell if the wire is in all the way it can be. But in general its still in not sure if its still all the way in also im not sure if this has anything to do with how loud the subwoofer is or the speakers.
