I bought the Shuttle SN21G5 a little while ago after my other computer died.
Anyways, I've had reboots initiated by certain actions in Windows XP that leads me to believe there is a problem with the CPU or the nforce chipset.
For instance, if I right click on my network connection is control panel and select disable, my computer will reboot.
Another time the computer rebooted is when I allocated a large amount of data at a time in a torrent program(something like 10GB).
The reason why I believe it might be the CPU is because of certain circumstances. Before I transplanted the CPU from my old computer, one of the pins on the bottom of the cpu was bent. I bent it back into placed and the cpu fit into the socket. I realize this can be dangerous.
