chuckm1020
- Jun 12, 2003
i just got a new abit nf7s , when i try to do raid, i set up the raid, then i format them, then it restarts and right before it goes to the installation the screen just turns black and does nothing. So i thought maybe its a bad hardrive. so i just plugged one hardrive into the primary SATA connector then formatted and then it went perfectly into windows installation. then i did the same thing with the second hardrive on the primary SATA connector and it went right into the windows installation. so its not the hardrives. so then again i tried the raid setup and it just stayed at the blackscreen. Why can't i get my computer to do RAID? Do you think that the secondary sata connector might have a problem?
Edit: I tried putting a single hardrive on the secondary sata connector to see if it would boot and it did, so its not the secondary sata.
