Max-Powers
- Jan 9, 2005
I am having a problem with a new computer I am putting together.
Motherboard: GA-MA790X-UD4P
Powersupply: CMPSU-650TX
video card: PNY GTX 260
I got all my power cables hooked up the way they should be, except there is still the, what the motherboard calls, ATX_12V_2X4 plug that has nothing plugged into it. After looking at the cables from my power supply, I see that the only one that looks anything like it is what the power supply calls the 8 pin EPS12V cable. The pins don't look the same, but it will plug in. (there is a couple hexagons where a square should be, but it still can fit) Is this where the cable is supposed to go or does it not need anything plugged into it?
Sorry if it sounds confusing, I have both instruction manuals infront of me and am very thrown off by the different names and pin arrangement (squares and hexagons)
