Problem with PC, plz help
yashiro
i had my system since july 2005, my spec:
Chaintech nforce 4 ultra socket 939
athlon 64 +3000 @ 1.8 ghz
1 gb ram mushkin dual channel
evga nvidia 6600gt
160gb HD
well the problem is yesterday i turned on my pc and was downloading some stuff from the web, browsing, makin a design in coreldraw etc. im a multitasker
:p suddenly my pc froze so i shut it down restart it and my avast antivirus had some issues like it wasnt workin properly so i unistall it and install it again with no problems but then it happened again my pc froze, here comes the nasty part, i shut it down again and turn it on again but my monitor wont turn on it had the orange light has if some video problem i saw the HD light on ... shutdown restart, the same i couldnt see anything, so i check the ram change it with another one from my other pc, the same, reset the bios jumper, nothing, my video card is pci express so i cant check that out 'cos i only have an agp card in my other pc :rolleyes:
but this is all too weird it ran with no prblem until yesterday, i cleaned all the pc but nothing
what else can i do besides chekin the video card with another one?
plz i need some help here, thanks
lol, dont ever buy cheap cases, the reset button was stuck and that's why it couldnt start, it was restarting over and over again!!
the case is
Antec Solution SLK1650B Black Steel ATX Mini Tower Case with 350W Power Supply
the only good thing about it is the power supply :rolleyes:
wich case should i buy to replace it???
I'd head over to the hardware forums and they will tell you to go to Newegg.com and buy a nice Lian Li case.
