Problem with OCing a PoV 6800 nu
C.T.
I have a PoV 6800 nu 128mb
The problem is that i never get to clock the card until i get artifacts. It seems to run fine and stable at i.e. 375 Mhz core - but at 380 it suddenly freezes (im able to escape the 3dmark03 test though) when i test it. The same thing counts for memoryclock.
Shouldnt it be abit of "buffer" space in Mhz between stable and freeze where i would get abit artifacts? Is it possible that there is a safetysetting somewhere enabled to protect against to high clocks - that i could turn off?
OC are tested with both Powerstrip and Coolbits 2.
