Problem with new overclock and powering on
mavi802
So I just finished overclocking my e6400 on an Asus P5B-E and ran it on orthos for 6+ hours. There is a problem however when I turn on the computer. When I press the power button the fans will spin up for about a second then stop, then about 3 seconds later the system will power on normally. This wasn't happening to me before when I was running everything on stock so I can only assume it is because of the overclock. Is this something that I should be worried about?
save your bios and try running everything on stock again and see if that happens, if it doesn't do it on stock its definetly your oc .... similar thing happened to me where i could do 12hr+ orthos without error but when i turned it off and try to cold boot it the pc would reboot again and again until it set everything back to stock again ... it basically means that your pc isn't stable enough to do a proper boot
that's the famous 'double boot' issue with 965 and p35 chipset that most motherboard has. dont worry about it.
