I finally assembled my SuperMicro GL board, 4 6282 extra spicy CPUs and some RAM in a Blackhawk Ultra case with a Corsair AX 1200 P/S. The motherboard and P/S are new. The RAM is known-good.
When I enable the P/S master switch, the DP3 LED does not illuminate as mentioned in various forums and the manual. If I hit the case power switch, the P/S clicks but nothing spins up. If I hit the power switch a time or two more, the DP3 LED finally lights up but then it starts blinking.
I've read through SuperMicro's troubleshooting steps for No Power and I figure I'll have some time to debug it tonight, but it means taking everything back out of the case, possibly going down to a single CPU/RAM combo and starting there.
Are there any other suggestions not mentioned in the troubleshooting guide? If I enable the P/S master switch and DP3 does not illuminate, is that a P/S or M/B issue?
As stated above, the P/S is new and I've never tried it in another rig. Could it be DOA? Or should I suspect the M/B? I might be able to scrounge up a Seasonic 750W P/S just to verify the M/B is good (I'd have to remove it from a working Windoze PC). Any other suggestions would be highly appreciated.
