mrmylanman
- Jul 13, 2008
I installed my Intel D35EC motherboard into a new case today, and I immediately noticed some problems at boot up.
1. A fan connector is dead. It's not the fan as it works when I use the other fan connector. I tried plugging it in to the CPU fan connector, that didn't work either, but it's a 3 pin connector, that could be why, I don't know. I am not using a CPU fan (NT-06 Lite heatsink butted up against the power supply fan)
2. Peripheral devices do not work until Windows is fully booted up. I cannot go into the BIOS by pressing F2, I cannot configure my RAID controller by pressing Tab, skip it by pressing Esc, etc, and I cannot select my operating system in the Windows Vista bootloader (increasing my boot time by about 35 seconds).
3. The boot up sequence is screwed up. It goes:
Boot-up splash screen, RAID controller boot-up screen (so far this is normal), boot-up splash screen (obviously not normal, but I do not hear the PC speaker make its 1 beep it normally makes), boot-up splash screen again, then Windows boots.
Once Windows is booted up, it all works perfectly normal.
I am considering reflashing my BIOS, using the package supplied by Intel, however I do not know if it requires a keystroke at boot up, and if the constant rebooting at start-up will damage this process, making my motherboard useless.
Thanks for any help
Thanks for any help
