Problem with my Mobo or Cpu?
Nirad9er
My current motherboard is 2 years old. For a while now, I've had to raise from the default voltage of 1.65 to 1.725 for the computer to even boot and stay stable without rebooting randomly. Under the bios, the 12v voltage settings reads 11.86. I've also noticed that since I had to raise the cpu voltage for the computer to be stable at stock settings, the temperature also increases as well, which is expected. Is there a problem with my motherboard suppling enough voltage to the cpu, if so, why does the temperature still rise above stock. Is my mobo crapping out and need extra voltage to be stable or could it be my cpu?
Thanks
Running whats in Sig
I tried an older generic 400w psu and the voltage read even lower, like 11.7ish
On any board older than a year old the first thing I check is the Capacitors...
The "bad cap fairy" was one busy lil' lady....
