Problem with my 7970's? 10s video inside
Gagnon
http://youtu.be/tR3Xnzk1-OM
Noise gets louder as I play XCOM: Enemy Unknown.
Doesn't matter if I put them in CrossFire or not.
I have adjusted the fan speed to the point where I can noticeably hear the fan so it is not the GPU fan. Seems to start up when I turn on my PC and after a few minutes goes away.
I'm driving an HP ZR30w monitor if it matters.
Open the case and locate where the sound is coming from.
I had a cheap PC with a PSU that made noises like that during GPU load. The PSU croaked (in the end literally), probably rubbish components and wasn't built to deliver nearly as much wattage as it specified.
Not a cheap PSU here, 1500 Watt Toughpower-1500M
I opened up case, guess I'll have to put it on my workbench and really take a good look/listen.
Sounds like PSU coil whine to me. When I had 2 7970's and ran 3dmark I'd hear it out of my power supply as well. Sucks as most PSU companies will not RMA for coil whine no matter how extreme it is. And even if they do RMA replacement units usually have the same issue as it's a design issue not a manufacturing flaw. :mad:
Have you tried blocking the PSU fan from spinning? That sounds a lot more like fan noise/rattling than anything I've heard from a PSU.
Good guess, I propped it up on my desk, took a better look inside. It wasn't PSU fan it was one of the 7970's, between the two they installed an X-Fi sound card which I don't use with my B&W MM-1's so I just removed the card and now noise free! The fan was rubbing against the sound card :mad:
What the hell!? Did you open the case to find the source of that rattling? That's not even remotely close to what a full load, vsync off, 7970 sound like.
LOL dude. You know what when I upgraded to the 1GHZ Bios my 7970s went from warm air shooting out of the vents to, AIR FROM THE DEPTS OF HELL THAT WILL BURN YOUR SKIN. So I just reflashed my 7970s to the regular ATI reference 7970 BIOS. I also had my X-FI HD between the cards. I am glad I removed it and enabled the onboad X-FI on the G1.Assassin. I think I might have damaged the sound card with that much heat exposure.
I'm just wondering do you have the reference design or the custom design 7970s? My reference design card fans are not even close to the X-FI to make contact.
