I think there might be something wrong with my Athlon XP 3200+
When I first got it (from anandtech forums) I hooked it up and threw a silentboost on it. That worked for a little bit, but then all of a sudden it would overheat very rapidly and cause the motherboard shutdown feature to shutdown the computer.
I thought a better cooling solution would be needed, so I got a watercooling kit from aerocool. That was even worse than the silentboost and I wouldnt even be able to get to the bios fast enough before the computer would shut itself down.
Well, I finally got a kamakazi cooler on it now and it seems to be doing OK. My problem is this. Even at idel the bios says the CPU temp on die is sitting about 70*C with the kamakazi on 4100rpm.
Now I dont know what the hell is wrong, but even trying to play a simple game of generals causes the computer to overheat and shutdown.
Do I just have some superhot rare cpu or something, I mean what the hell is going on.
