Problem with MX500 mouse
Diablo2K
Sometimes when I stop my mouse, the curser keeps moving. It is almost always slowly moving to the upper left. This happens about 20% of the time when I stop my mouse. I am not useing any drivers other then the supplied window drivers. It isn't a major problem however is very anoying!
Are you sure the optical sensor is clear of obstacles? Check it and remove any hair or other such grime that is in the way.
yeah exactly. on occasion, mine have done that because of a very fine hair in the way blocking the sensor.
There was a hair and I removed it, so far so good, Thanks, I didn't see it the first time I looked so I looked harder after your post.
And here I thought we didn't have to clean these mice, at least that is what they advertise
[edit] it has done it a couple times sense the removal of the hair, I cant see anything in there now, so maybe it is something else :D
[/edit]
