Problem with MSI Neo2 Platinum (939 Socket)
ryanjg11
I have installed this motherboard, along with a refurbished A64 3500+ 939 from Newegg. Slapped my Thermalright XP-90 heatsink on it, plugged in my PC3200 dual sticks and Nvidia 6800 card.
When I hit the power button, all I get is a long constant beep with no POST, nothing on the display whatsoever.
I have a hunch this is a defective CPU, but I wanted to see if anyone else has had this problem and if they were able to solve it. Thanks!
Oh, and the D Bracket diagnostic tool is reporting the following LCD configuration:
RED GREEN
GREEN RED
The rest of my specs are in the sig. I have a good power supply.
Just to reiterate, from the very second it turn the power switch on, the constant beep begins and never ceases. So it's not really a beep, but just a constant sound.
ubern00b15 said:
Ill trade my GA-K8NS Ultra 939 and like 15 bucks for your mobo......let me know
Last I checked, this post was not in the For Sale area. Thanks though, for your tremedously helpful post. :rolleyes:
I had a similar problem with my MSI Neo 2! Except...mine would POST but then it would go into a restart cycle, or it would post restart and then not do anything. I was quite angered. I think my problem however, was the PS. I unconnected everything, thought logically about in what order to plug things in and together, then it POSTED correctly. Maybe check your connections? Your jumpers may not be right either. The Diagrams were quit unhelpful,but try re-doing those. Other than that, I wouldn't know.
everything seated correctly? try different ram, or one stick. Are they in the right slots? Could be a simple thing, I don't really know, but a run down of the basics is always a good place to start.
RED GREEN
GREEN RED
Try booting with one dimm of ram then update the bios to F6, It wont work with F3 bios in dual channel.
Which BIOSes are F6/F3? My MSI K8N Neo 2 Platinum is BIOS rev. 1.3, the latest release. I think you may have the wrong mainboard.
The D-bracket code, according to my manual, is halting at the CPU initialization. I'm usually not one to bet on the CPU being bad, but you said yours is a refurb. I'd put one stick of RAM in, clear the CMOS with the mainboard jumper, hook up only the basic peripherals like mainboard, hard disk, floppy, and graphics card if it requires it, and try to boot again. If you still get the error, I'd RMA the CPU.
Remeber that you need BIOS version 1.2 or higher to use this motherboard with a 90nm processor.
I had this sound once after I installed everything. It was my video card not being plugged in with the 12v molex connector. You may want to double check that. Also you want to flash your BIOS to latest version and double check that your memory is installed securely and correctly.
1.4 is latest.
I had also that problem when my video card was not plugged in. One loooooonnggg beeeeeeeeeeeeeeeeeeep
Sounds to me like the 12v connector for the vid card is unplugged or you dont have enough power supply if it is plugged in and its dropping the amps to low for the videocard to work. check to see if the 12v connector is even plugged into the video card and if it is when you power up the machine see if the solid beep you have is coming from the videocard speaker, as well as the vidcard fan will probably not be running either. forgot to plug mine in once and it happen to me. Something new with the NV6 series of cards for the speaker and the amount of power needed.
The Captin
pandora's box said:
1.4 is latest.
Must have been just released, as I've only had my board two weeks and checked when I installed it. Thanks for the heads-up!
Yep, that was it. Damn, I feel pathetic. I thought only the Ultras required a direct molex connection... Plugged it in and we were good to go.
One new problem has arisen however. MBM5 is not reporting my CPU temps correctly. Is anyone able to get accurate CPU temp reporting on this motherboard from within Windows?
I totally forgot about that, that happened to me a couple times when I was putting together a few systems. Simple mistake.
