problem with msi kzn2 delta 2? :(
umcpgrad
so anyways new comp for a friend..... I fired up the m/b installed everything with cpu, ram, graphic card and etc...
and yet i noticed there is no beeping noises... (everytime comp beeps when it boots up).. but for some reason this m/b doesn't beep... so yeah.. everything boot ups fine...so i went to play around in the cell section.. aka the ocing section...
so I guess i turned the fsb... to 170.. it posted.. 180.. posted..190 didn't post.. 184 fsb it didn't post.. and when i rebooted. it say floppy error.. but I didn't put floppy... because my friend will not use it..
so after I turned that off... and turn back up.. the monitor would just shuts down after few secs.. but it does say connection are fine.. and etc..
so I swapped out... video card, hardrive..ram..video cable...
i took out battery of the m/b and I reset the bio info a lot of times...
I am afraid it might be motherboard and cpu problem.. could it really be it?!?!? oh no!! :confused: :mad:
i went on msi site.. and it aint that helpful.. I need help please!! :(
btw excuse my writing ... it has been a long night... be doing this for 8 hours now... and had no sleep... had only 2 hours.. of sleep..
Ok i've got that same motherboard, lots of people have had problems regarding oc'ing. I havn't had to many problems other than it hating old durons (650, 750 Had to pencil in bridges for voltages to get them to work)
Did you mess at all with the fsb jumpers on the board. The ones for 133/166fsb and the 200mhz one. Those are 2 seperate jumpers if you've changed those make sure to put them back to the original positions. In adition one thing i've noticed is after any jumper changes on the board I had to reset the bios to get them to work. Oh also do you have the d-bracket installed its a little led device that tries to tell you whats wrong when your computer boots up. Hope this helps, feel free to PM me with more ?'s i gots lots of oc experience with this board
sorry about the horrible post that I wrote hours ago.
I have msi kzn2 delta 2 motherboard,
I have the kingston value ram pc3200 1gig
geforce 6800oc bfg
3 hardrives, 200 gig maxtor, 250 gig maxtor, 200 gig wd
and tdk 40x cd burner, nec 8 x dual layer dvd burner
with 2600+ amd tbird.
the case that I have is the kingwin mutant x silver/ gray gaming case with "420w" power supply from newegg....
any other infos ?? thank you all for the help... :(
1 correction the m/b is msi k7n2 delta 2
and I just found the d-bracket...
and it has 4 lights, whenever I start the comp it shows
2 on top 2 on right
red, green
red, red
I went on the msi website... and it doesn't really say anything about what that means... :confused:
well in my opinion that motherboard sucks for overclocking first of all. Second of all, if you keep trying the thing will post and get into windows just keep trying, i had the same problem and it eventually worked.
here it is a general background on the situation.
the comp is brand new, and at first it booted fine, bio, I hit del and played around the settings.. I tried to oc.. and btw this system has no floppy drive... then suddenly i played with the fsb.. and the system wouldn't boot to the bio screen and it said floppy error blah blah.. that is when everything started... whenever I start the comp.. never "boot" up not even the bio screen.. the monitor deplays nothing .. and I tired to take out the battery and the clear cmos jumper.. nothing.. the computer turns on... but the monitor deplays nothing.. and the video card is fine, and etc.. I tried it on another comp.. :(
http://www.msicomputer.com/support/sup_tshoot.asp#1_3 There are the D-Bracket codes listed there, if i read your led light status corectly then hat corespondes to the memory detection test. I used Kingston value ram and it worked, i had some no name shit that didn't work so the board is pick with memory, try using diffrent slots on the motherboard (IE slot 1,2,3) Maybe unplug eveything you don't need, you've got a ton of stuff for that system and I am starting to wonder if maybe the PS might be part of the problem. If possible could you try another cpu in there. IIRC my board did make beeping sounds so maybe the board is hosed, hope that helps.
Well since its not beeping i'd say it is most likely the motherboard, although its rare fro one to die while overclocking, but if you can try the ram in different slots and a different cpu, maybe even power supply too.
another short update, before I do something more. Sorry to bother you all with this.. :(
I plugged in a new compusa 500 watt powersupply and it still does the samething.
I also plugged in a new 256 pc3200 pny ram and nothing .. it does the samething..
I am now RMA the motherboard...
and the cpu ran out of warrenty now..
do you all think it is the motherboard now??
i think is I got the cpu 30 days ago... it is oem... I guess either cpu/ or mb is a bust... but can't be too sure... :(
