Problem with Logitech Cordless Desktop Wave on PS/2
RadonEx
Hi all,
I've got a problem!
Well yesterday i bought the Logitech Cordless Desktop Wave (USB).
A short story before:
I had a mouse and a keyboard already (also from Logitech), I had connected them in USB Ports and it worked well, but recently none of my USB Ports work anymore (don't ask me why, was a stupid thing from me..), well so I took 2 USB to PS/2 adapter and connected them to the PS/2 port! Worked perfectly! (The mice was the mx 1000 (cordless / laser) and the keyboard was with cable).
But now i bought the Logitech Cordless Desktop Wave, because of no USB Port works I connected it directly via the USB to PS/2 adapter to the PS/2 Port! But the mouse and the keyobard don't work, the receiver or sender has power on it, because it blinks when I click the connect button....but still the mouse and the keyboard doesn't work...
Is there any way to solve this ?? Maybe I need a driver, because PS/2 isn't pnp...
And yes I installed logitech Setpoint 4.x and I tried the whole thing on another Computer (USB) there it worked!
OS: Windows XP Pro
I hope you understood my problem, even my english isn't the best!
Greetings
Radon
I don't believe that the Logitech Cordless Desktop Wave can be supported by the PS/2 bus. And XP Pro, starting with Service Pack 1, has always had USB drivers built in.
You probably have a bad USB bus on your motherboard, but without troubleshooting the motherboard, there's no way to be certain.
