problem with HP LP 2065 when switching inputs
My HP LP2065 monitor works great when only one of my PCs is powered on or if I don't switch inputs back and forth, but when both are powered on and I use the input button to switch from one to the other the screen:
1) gets green horizontal lines running across it and/or
2) blacks out for a second or two, then displays the image, and repeats the cycle
It's a little better when I drop the resolution down from 1600x1200 to 1280x1024, but I still have the same problems, just not as frequently.
If I power off one of the PCs, or if I don't try to switch back and forth, then the image is stable. I am using DVI for both connections. Firmware version is 119.
HP driver on my Windows 2000 system is 3.0.0.0. I can't seem to find a newer one for Windows 2000.
No HP driver on my XP Pro system yet. Waiting to see if I have a setup/hardware problem first.
The main reason for buying it was the ability to switch between two PCs without the need for a DVI KVM. Has anyone else seen this? Any help you could provide would be greatly appreciated.
Mike
