Problem with HL2 EP1
Alright, I'm trying to play HL2 EP1 but the game keeps freezing up on me, I can barely alt tab out half the time, I usually end up hitting the reset button, because windows 80% crashes as well. I kinda got lucky a few times and managed to shut it down via tskmgr, Each time a memory dumprep error comes on, So this last time I checked system memory use while HL2 EP1 was shutting down, well apparently over 1GB of my memory was being used with only HL2 running, and HL2's thread was using up over 500Mb of memory... And I was only about 2 min into the game. Here are my specs, is this normal? what could be the problem?
A64 X2 3800
Asus A8N-E
2x512 GEIL PC4200
Sapphire X1900XT 256
delete it and redownload it through steam.
you are using steam right? and you did buy it, right?
Yep I bought it and using it through steam. I tried reinstalling it, tried reinstalling drivers as well. I've noticed if I lower texture detail from high to medium it uses less system ram as well as video ram and it has been running with no crash, although in console it keeps saying cache error. When running everything max I get about avg 50fps but video memory drops to about 12mb free, maybe its using up all the video memory that is causing the crash? I remember in Oblivion when the texture detail was really high the video memory would be used all up and fps would drop to like 0-5, until I restarted oblivion.
