CounTDookU23
- Nov 28, 2004
Hello. I just installed my GTX 580. For some reason Windows 7 64 is not detecting the card.
Windows boots just fine..... I get no beeps or anything off the card. However I get no hardware detected..... and it does not show in the control panel/devices. The monitor is hooked up to DVI 1 and allows me to run in windows just fine. I have tried to reset the bios, change the power plugs.
- Note I do not have an extra 8 Pin connector on my PSU. The card did come with an adapter to turn two PCIe in to one 8 pin. That is what I used to connect the 8 pin.
Can anyone help me out in figuring this out..... I have no clue what else to do. I was just running a 5850 on this system. Uninstall-ed the driver using Revo Uninstaller and some ATI driver remove tool just in case.
Running on MSI GD65 + PC/Power Cooling 750 Power Supply.
