Problem with GenMay and Mobile Viewing
ComputerBox34
For whatever reason, Genmay refuses to revert to the "mobile" view. All the other forums will go into mobile mode but genmay won't.
Anyone having this problem?
also; what's the deal with the white text for the thread starters? Is that permanent for is it going to be changed back to normal later?
Everyone is having this problem. You can test it on your pc to see if it's working or not.
It's the only part of the forum that doesn't work with the mobile view.
Wonder what's up with that... It's not designed that way right? It's an issue that's being worked on I assume?
I do believe they are aware of the issue, but probably other more important things to address first.
There is no problem, Kyle is forcing that style for the genmay forums, not sure why, you will need to talk to him about having that changed.
Try now? This is simply a left over setting from the old days.
Working good for me now. Now to subscribe and loose countless hours of my life..... :D
