Problem with FrameRates on 8800GTX need some help.
mx1mx1
I am playing a few games on my new system with a EVGA 8800GTX and this computer is really fast and good but I am having one problem in a few games.
The dramatic changing of the frame rate causes the games to stutter. It kind of looks like frame rate lag or something. It only happens when the frame rate changes. It isn't a problem of low Frame Rates it is a problem of "changing" frame rates. If I could somehow force the games to run at a certain frame rate and stay there I know the problem would go away. Is there some kind of a program or something to lock framerates? I have this problem in Silent Hunter 4 and a couple other games I have tested so far. (just got the computer)
I sometimes get 200 or 300 Frames per second in some games at times but the problem is when the framerate changes. If the framerate changes from say 200 to 150 it creates a non smooth stuttery laggy look to the game.
Vsync helps a little but only if the framerates can stay as high as the refresh rate. For example, my refresh rate is at 100HZ so if I can maintain 100FPS in games it is perfectly smooth. but if the frame rate drops below 100 or fluctuates between 80FPS and 100FPS it becomes not smooth and stutters. It is kind of like the terrain stutters. Moving the camera you can see the terrain or objects ingame, "dragging" Buildings. ingame characters, airplanes, ingame objects etc.
I tested this by temporarily lowering my refresh rate to 60 and turned vsync on so it locked the frame rate to 60 in my games and it was perfectly smooth. So I need a program to lock the FPS. I use 100HZ refresh rate on my 19" CRT/
60, 70 or 80 FPS should be perfectly smooth and it is as long as it's not changing. When the FrameRate starts changing from say 100 to 80 or so it looks really bad, looks laggy and stutter and looks like low fps.
Vsync would fix this problem if my computer could maintain 100 FPS at all times but it cant.
Is there some kind of program or setting or a way in Silent Hunter 4 (the game im currently playing) to lock the Framerate at 60FPS or so?
It does do it in a couple other games to but I haven't had a chance to test much yet.
System Specs.
Asus P5B Deluxe
Intel E6850
EVGA 8800 GTX 169 drivers (tried old ones too)
2 GIG crucial
Seasonic 700 WATT
500 GIG Western Digital
Silent Hunter 4 for sure so far. It is a newer computer and it could just be a problem with Silent Hunter 4. I have been testing some more and it seems like a problem with vsync maybe.
I use 100hz and with vsync on as long as I maintain 100 FPS it is perfectly smooth. But if it drops below 100 even if it just drops to 99 or 98 FPS = instant stutter, lag, non smooth animations and game objects.
You would think the difference between 100 FPS and 98 FPS would not be noticeable but it is dramatic. It looks like it just dropped down to 15 or 20 FPS even though fraps reads 98 FPS. Unless fraps and the ingame FPS counters are lying to me?
