Problem with ForceIPBind on Windows 7 (x64)
Hyphen
I am desperately needing a solution to binding certain applications to specific network interfaces. ForceBindIP seems to be my only solution. Although the website claims it works up to XP, Google says that many users running 7 have had it work successfully. I have UAC disabled, yet still:
Does anyone know why this is happening? If not, does anyone know a viable alternative to ForceBindIP? I'm a gamer and I'm addictively trying to torrent on a secondary connection while playing games online.
'ForceBindIP' is not recogonized as an internal or external command, operable program or batch file.
Where did you place the executable? Did you add the path to the system's "Path" environment variable?
Also, as Jay_oasis said, paths with spaces needed to be in quotation marks
edit: C:\Windows\SysWOW64 is not in the PATH environment variable by default, as far as I can tell. This is why the initial error when trying to run ForceBindIP from a location other than the folder the executable exists in.
