Problem with flashing my mobo
ultitaria
--MSI p6n SLI--
my hardware: pentium D 960 (3.6ghz) **, geforce 7900gt, mobo^^, sony w/rw, samsung dvd reader drive, A drive, creative X-Fi, 2gb corsair value ram
**my mobo thinks my cpu is a pentium 4 3.6ghz
DIRECTIONS GIVEN TO ME BY MANUFACTURER
Special Note:
The BIOS and DEVICE DRIVERS contained here are exclusively for Micro-Star products only. Micro-Star assumes no responsibility for any damages resulting from improper use or lack of technical expertise.
WARNING!!!!!
DON'T FLASH FROM A FLOPPY DISK!!!!
DON'T FLASH WHEN YOUR SYSTEM IS RUNNING FINE!!!!
DON'T FLASH IF YOU DON'T KNOW WHAT YOU ARE DOING!!!!
Award BIOS Flash Procedure
1. Know your model number
a. Open your case and look for the MS-XXXX number on the motherboard between the PCI slots, also check the version number that is written there as well. (Some motherboards are named like K8N Diamond; make sure you have the right version number)
b. Boot up your system & take a look at the top left screen during POST, you should see something like “W7100NMS V1.1 021705” This means the board is MS-7100 with BIOS version 1.1
Hint: Many systems are clearing this message very fast, the bios version is then unreadable, and you can either press “PAUSE” or disable the “Quick Boot” in the BIOS setup.
2. Download the BIOS that matches your motherboard AND version number (some motherboards are named like K8N Diamond; make sure you have the right version number). BIOS can be found according to the CPU type of your board like if your CPU is AMD 939 type then look here
http://www.msi.com.tw/program/produ...st.php?kind=1&CHIP=68&NAME=Socket 939 (AMD K8)
if you cannot find the BIOS that matches your board, try here http://www.msi.com.tw/support/bios/more.php
3. Extract the BIOS-archive that you have downloaded by double clicking to c:\test
4. Boot your system from a Win98 or WinME boot-floppy.
How to make boot floppy in case your don’t have it ready:
For Win9X, You can type [C:\ format a:/s] from the DOS prompt.
For WinME, You can make a boot floppy from control panel--> add/remove program-->make boot floppy. Remove autoexec.bat & config.sys file if there's any.
For Win2000, there's no way to make boot floppy, so you have to either use Win9X or WinME boot floppy.
For WinXP, you can make a DOS boot disk. Go to Your Computer, right click drive A:, select Format, select copy system files.
5. When you get the A:\ prompt, type the following sequence:
C: <enter>
cd\test <enter>
C:\test> awdfl865 BIOS file
(To save or not to save old BIOS is the user’s decision)
6. Reboot your system when prompted
WHAT I THINK IS GOING WRONG:::::
at the bottom of the directions (extended) it says flashing mobo for non-fat file system. my HD is NTFS i think.. so
WHAT I NEED TO KNOW IS:
should i do the non-fat flash procedure?
It doesnt matter what filesystem you have as long as you are in Real-Mode. My recommendation would be to get a floppy, format it (format a: /s), copy the flash utility (the file with extension .exe) and the BIOS file (the file with extension .bin) to the floppy. Reboot. Make sure your system booted from floppy (set in bios). If so:
"flash_utility.exe name_of_bios.bin" and follow the prompts.
