Problem with DFI Ultra Infinity
cerebrex
Just got the DFI Ultra Infinity and I'm having problems with the power suddenly going out among other things. It's coupled with an AMD Athlon XP 3200+, Micron PC3200 DDR400 ram, GeForce4 Ti 4200, a 200GB HD and a couple of DVD drives. When I try to install windows on it, it goes to the setup screen, copies the files, then restarts. After that, it tries to go back into the CDROM to boot, and if I tell it to boot from IDE0, it doesn't even try to load. Also, at seemingly random times (with good temperatures), the computer will just shutoff for an unknown reason. It has a Rosewill power supply with either 400W or 450W... don't remember, but it is rated to run a Pentium 4 just fine... or so the sticker on it says :)
Any idea what the problem here is?
I put my working hard drive into the new computer. It says:
-verifying VMI pool data.... update success
-backup cmos....ok
-error loading opperation system
any reason why i would be getting this problem???
It doesn't lose power at all anymore, but it is still giving me the same crap. It won't say anything at all booting from his drive, and using mine says "error loading operating system"
Try clearing the CMOS to get it up with the working drive. You may also want to flash to the latest BIOS.
I've flashed the bios and tried both drives, different IDE slots, different cables.... thinking it might be the mobo.
Might be the motherboard, try your old motherboard and see if it boots up with the same hardware.
~Adam
Also, try to remove excess hardware and keep the bare minimum then test it. If it works, it is a power supply issue. Otherwise, it is a motherboard issue.
I know for a fact that the problem is your bios. It isn't recognizing the full size of the hard drive. Flash to a newer mobo bios and you should be fine. Hope this helps :)
first try to reformat hd and if windows sp1 is not installed it wont recognize full 200 mb. second and a big one are u trying to overclock this rig with that psu? what are your bios settings? need more info.
I had similiar problems. What version of windows are you trying to load? Well I guess it doesnt matter. I built my computer about 8 months ago and couldnt install Windows XP. Here is what I did to fix it. I had to do a DOS based install because I only have the upgradeable version. But anyways go into your computer's Bios and change the front side bus speed from 200 down to 133mhz. Don't worry you can always change it later. For some reason the computer would screw up copying the installation files at these high speeds. Anyways, then remformat your hardrive and do a Dos based install only!!! It should fix your problem. Send me a private message if you have any questions.
I have no idea what to do now. I am trying this new system with 2 harddrives. My previous 80GB Seagate drive, and the new 200GB Western Digital drive. Both have Windows XP installations on them. The 80GB has normal XP Pro and hte 200GB has XP Pro SP2. When I try to load the 200GB it gives me PXE errors, so I switch off the onboard LAN so it doesnt try to boot from a network. After that it tells me I have a "Disk Boot Failure." It then tells me to insert a system disk and press enter. When I try the 80GB it says "Failure loading OS," or something like that. ANY ideas on what the problem is here? I have switched cables, IDE slots, and have no idea what to do now. Any help would be greatly appreciated.
The motherboard's ide ports/chip(s) are bad, take the motherboard back after u try resetting the bios and/or updating the bios.
~Adam
