Problem with DFI NFII Ultra Infinity
CVNet1
Well, I got a 2600XP-M 45W and a DFI NFII Ultra Infinity recently in order to pull a ~2.6ghz clock with the 1gig BH-5 Corsair ram I've had all this time. Things were going just fine, as I was able to hit 2.4ghz @ 200mhz FSB immediately after starting the system for the first time @1.65 volts on the processor and 2.8V on the ram and normal voltage to the northbridge and the AGP chipset. I pushed it a little more to get 2.6Ghz @ 1.7V and decided to try installing windows. Not long into the install I get one of those BSOD's so I decided to run Memtest86+ and see what was going on. Memtest86+ didn't show any errors after 2 passes, but I noticed it was reporting that I was running the Ram as Single Channel (not Dual Channel) which was a little strange since one stick was in the blue colored slot and the other in the black colored slot. My solution to this was to power down the computer and unplug the power wait a few seconds and switch the first ram stick in the blue slot to the 2nd blue slot to see if perhaps the slots were just color coded wrong. Put it all back together and next step is to plug in power flip power switch and press the power button......... nothing. No fans start spinning, no lights turn on, the power lights on the motherboard indicating +5V standby power don't light up or anything. So I check the power supply to make sure that
A) its plugged in
B) the switch is flipped to the 1 and not the 0 in back
C) the ATX cable and +12V cable is plugged into the motherboard properly
D) It doesn't smell like Ozone.
Nothing out of the ordinary there as it seems to be fine. Still no power seems to be getting to the computer. Next step is to see if somehow I unplugged the Powerswitch cable from the motherboard accidentally, nope its in there right, I reset the bios (after unplugging everything again), plugged it back in and still nothing. The computer is plugged into my APC 1400BackUPS along with the monitor, and the monitor is recieving power just fine (ran UPS self check and no problems from that). However, the computer does not seem to recieve any power at all (there does not appear to be any physical damage to the motherboard of any kind, so I'm at a loss for figuring out why the motherboard won't power on or show signs that power is flowing
Full System specs
430W Antec True Power
2600XP-M 45W
LG CDRW/DVD Rom
1gig (2x 512MB) Corsair CMX3200C2 ver 1.1 --BH-5
ATI Radeon 9800pro 128MB
WD SE 80gig 7200RPM IDE drive
floppy
SB Audigy
edit: One more thing, this was only Day #2 of testing. Effectively this was the 6th attempt to boot up the system, although before this time it was showing no problems or signs of problems (there was the failed Win XP install, but perhaps that was an OC related issue and not a MB fault). I do realize that these boards will burn themselves out if pushed to the maximum OC settings, but I wasn't overvolting anything significantly 1.7 VCore and 2.8VDIMM are hardly high voltage settings for these boards. The Power supply showed steady voltage output while it was on and didn't get any warmer than usual. The CPU temps were steady at 45 and below the whole time I was overclocking and running stuff (I really am impressed with the SLK900A's performance when linked with a 92mm fan).
anyone seen this before or have some idea what might be the problem?
PSU could have blown its internal fuse.
That kind of setup takes some serious power.... you arent far from mine, and I need a 550W PSU to get the job done. It's not just raw power rating, but rating at full load with raised temps inside the supply.
Ive literally BLOWN UP 3 or 4 supplies in my day with this level of load vs capacity.
Fortron 530W, SuperFlower 550W, Antec 510W, PC Power+Cooling 510W.... those are the 4 selections proven bulletproof. The Fortron350W w/120mm fan is the only "budget" supply that has a shot at really handling high loads.
Good call. I did the wire trick on the PSU to see if I could get it to power on or not. Connected a wire to the green ATX wire and to ground on ATX cable with power on and plugged in (not to motherboard) and NADA. So looks like I've blown this PSU's fuse or something bad happened to it. Anyone know how Antec RMA process works? These things do have a 3 year warrantee according to Antec's website. I have an invoice for 7/13/03 so its still within warrantee. I just need to get a RMA I guess. Hopefully they treat customers well, this is the first time I've ever heard of someone having to RMA an Antec PSU, much less me being the person having to do it. Its kinda odd I think that the PSU latching protections for overcurrent draw and what not failed to protect it from blowing the fuse.
Actually, that might not have been 100% correct. I think my original Antec 430W True Power is ok and working fine (I'll have to test it tomorrow). Turns out my power cable from the wall outlet to the PSU must have been bad. I ended up reinstalling everything into my case so I could yank out the 430W Antec and throw in a 550W Antec True Power that I had in this other PC. The 5V standby power did come on when I plugged in the same (bad cable) to the PSU, but it almost instantly went back off again. So I tried another cable and now things are humming along at 2.5Ghz @ 1.65Vdimm and 2/2/2/6/1T timings on the Bh-5 ram in dual channel mode. All in all, it was probably best that I yanked everythign as I was able to do an excellent job on rewiring the PSU and I turned a couple fans around that were blowing air out so they now blow air in and what not. Anyway, thanks for the reply uwackme, I'm just relieved that I don't need a new PSU (or at least I think the 430W is good, but I guess both the cord and the 430W could have been bad). Anyway, I'll probably be posting my final OC when I get everything set up the way I want it. I'm shooting for 2.7Ghz.
