problem with dfi lanparty ultra-D
I was updateing hte bois one day useing there winflash thing they got over there on dfi's site and well i did that and then everythign messed up. Like when i start my computer i have this error and it jsut loops around until i reset the bois by the battery.
when i start/reset my computer it gets to the point of where it says backing up CMOS and then it jsut resets. It don't even say backing up CMOS or anything it jsut goes black and then reset i have already tried to install it with a floppy disk to see if it fixed the problem but it didn't and i am stuck at this point of where it jsut resets unless i reset the bois.
good guess however i had this happen then i installed a floppy and then did it that way which it is still doing it. :( but i'm gonna try that cd thing i hope it helps.
10:1 says the cd does the trick
yeah hope it helps... really dont does bios flashes in windows... they have a high probability of failure, expecially if you are OCing....
i hope it works, otherwise you'll have to get a new bios chip, turn the PC on, remove the old chip while the PC is on, put the new one in, boot the CD and then flash it.
most of the time this works and there is a thread on it on DFI-streets. if the CD doesnt just work I would post on DFI-streets and someone can figure it out and walk you thought it there...
jsut a update i tried the cd thing it didn't do much so i went ahead and ordered hte bois chip from tmod over on those forums and jsut got it in today and it works great. and no more errors or anything guess i learnt from my mistake :D
