I'm putting together a new dual-core machine. I feel that I know a fair amount about hardware, building machines, and generally troubleshooting them ... but I am positive that most of you guys know more than me. Hopefully one of you has the answer to my problem.
Before I begin, let me explain my configuration. I have 3 Ultra ATA hard drives and 1 optical drive. The board that I bought (Intel P945PSN) only has a primary IDE connection on the motherboard. There is no secondary, so I installed a PCI controller card which is currently not being used by anything.
Initially, I had a few problems and messed around a bit and got it to boot without issue. The configuration at that time was with my boot drive + another hard drive leading to the primary IDE input on the motherboard. I had the other two devices plugged in through the controller card, but since I couldn't install the software (no optical drive!), I was stuck. I also couldn't install the motherboard drivers and, in turn, couldn't reach the internet as the ethernet wouldn't automatically configure.
So, realizing my dilemma, I took it all apart, and set it up with my boot drive and optical drive together on one cable, and the other two hard drives on the other. Attempting to maintain the good luck with the primary IDE input on the motherboard, I put both the optical and boot drive in and ... no dice. It won't detect anything anymore, and just reads that I have no available boot device.
What should I do? I'm lost, to say the least. I'm just sitting here completely clueless. Thanks.
