Problem with Default Apps notification on startup in Windows 10
PJP
Sometimes when I turn on my PC, this notification appears. :confused:
I was wondering if there is a way to disable this certain window from popping up, as it has become annoying to hit Ok on every startup.
Thanks :rolleyes:
I never have that window popping up when I turn my PC on. Some program must be running and it needs to be set as default or something. Either that or you need to go through and verify that all you default apps are setup. Otherwise, disabling it would be sort of like putting a piece of tape over the idiot light on the dashboard of your car. (Ignoring the problem would not fix it. :D )
perhaps chrome? I know on windows 7, chrome runs as a background process at startup if you allow it. If you do the same in 10, without setting chrome to default browser, it MAY be responsible.
