Problem with connection of third LCD
Hello,
I have a problem. I have 3 LCD dell u2412m a motherboard gigabyte GA-Z77-UD4H. According to description it supports 2 LCD monitors on Intel HD 4000. I bought older graphic card Nvidia GTX260 with 2 DVI outputs. If i connect both of them, they work. But when I wanted to connect third monitor using the displayport, it didn´t work. Can you help me how to connect these 3 monitors on one PC at the same time? Ideal is to connet two of them using GTX260 and one LCD using Intel HD4000. Thanks
CPU : Intel Core i7-3770K 3.50GHz | Crucial Ballistix Tactical 32,0GB 1333MHz | Gigabyte Z77X-UD4H | 1792MB NVIDIA GeForce GTX 260 | LCD : 3xDELL U2412M | 256GB Samsung SSD 840 PRO | 2x250GB WD Velociraptor 10000rpm | 2x1000GB WD Velociraptor 10000rpm | 1TB SAMSUNG HD103SJ 7200rpm
