problem with case
Hi. i bought case Suntec a605, and now it doesnt turn on. Also there are few wires where i didnt find the place to connect to. These wires are: Tube 125*C, Hdd Lead looking like slave + other one with same appearance.
Thanx.
Tried looking for that case on google, and had a couple places that sell it, but nothing with good enough pics that I could try to figure out what you're talking about. Any chance you can provide a link to the site where you bought it from? :confused:
As far as the wires you're talking about, I have NO clue what you're referring to. "Tube 125*C"??? Does your computer case have a temperature readout, or what? HDD lead looking like slave.......um, slave? Slave for what??
Bottom line, with the info you've provided, I can't do much for you, and doubt anyone that hasn't seen your case in person could. Like I said, please provide more info, like a website link. Also, did you follow the instructions for hooking up the various connections from your case to your motherboard? Make certain you have the power switch connector in the right place, as having that just one pin out of place can keep your system from powering up. Also, and I don't mean to imply you're dumb or anything (I've just caught myself a couple times doing stuff like this), make certain that your power supply is plugged in tightly to the motherboard, and that your power supply switch (on the back) is turned on. I can't tell you how many times I've tried turning on a system that had the power turned off to the power supply! :rolleyes:
