After reading a few threads on here I was ready to go ahead with the 780g/4850e recommendation that seems to work for many people but then I found this article on Anandtech http://www.anandtech.com/mb/showdoc.aspx?i=3430&p=5 where it mentioned problems with 1080p Blu-Ray content because of lack of support for 24fps playback. Here's the quotes from the article:
"The AMD 780G/790GX results were very choppy at times; even when they seemed smooth we experienced audio sync problems.
The only platform that can properly handle 24 fps output is NVIDIA's GeForce 8200/8300. It just works. "
Can any of you that have this HTPC setup confirm or deny that this is an issue? The article is dated from October 14th so it's not that old, but I can't find any other mention of this specific issue with the 780g chipset anywhere else on the Internet. Perhaps a driver update fixed this problem? This is basically the one thing stopping me from proceeding with my purchase. I was either going to go with this http://www.newegg.com/Product/Produc...82E16856110096 (barebones model that uses 780g chipset) or this http://shop3.frys.com/product/5726492 (pre-packaged acer using nvidia 8200 chipset). Small form factor is a major consideration for me hence my choice between these two units.
Again, can any of you that have this HTPC setup confirm or deny the 780g chipset has an issue with stuttering 1080p/24fps playback when the camera pans? Thank you.
