gigamosh57
- May 31, 2001
Earlier this week I lost the password to Faronics Deep Freeze on my computer and have been trying to remove it. After numerous failed attempts to crack the program and its deep embedding on the hard drive, I decided to just f-it and format and reinstall.
My comp runs a Sempron 2800+ Running on a BioStar K8M800-M7A motherboard. My hard drive is a Seagate ST380811AS 80gb, SATA.
1st attempt: put in Windows install disk and attempt to format and reinstall normally
result? Windows setup can't see the hard drive (I presumed because not IDE).
2nd attempt: enter into BIOS and change chipset SATA to access hard drives like IDE.
result? Windows setup can see the hard drive and begins the format and reinstall process. I delete the 20 gb system partition and attempt to format and reinstall there. The formatting process gets to 59% and stops responding.
3rd-5th attempt: same as #2 except I try formatting a smaller partition (10gb). This time, the formatting process completes but when windows setup is copying files over (still in boot-disk-setup, not into windows yet) it hangs in various places.
6th attempt: same as #2 except, inexplicably, the boot-disk copying works. Once in the windows-based setup, though, BLUE SCREEN OF DEATH. Error: "STOP". No problem with files, no faults in copying, just STOP. Like the hard drive had been unplugged.
7th attempt: after googling around a bit, I find that I really should try to keep it in SATA mode, so I need the SATA driver. When the windows boot-disk setup asks me to "Push F6 if you want to install 3rd party SCSI or RAID drivers" I can put in a floppy of what I need. Problem: Legacy motherboards have no available drivers on their "support" website.
Where can I find drivers for this motherboard?
Do you think SATA access is really the problem?
Has anyone had similar random shutdown problems with Seagate SATA drives?
