I just put a 6800 O/C in my MSI NEO 2 Platinum and it's all messed up. I am using a 400W P/S.
The text at the bios is all funky looking and barely readable. It boots into windows just fine but there are black lines all over the screen making everything almost unreadable and definitely can't play a game like this.
I don't think it's a heat issue because both fans on the card are running and the case is open and it happens from bootup. I also tried the card in an older computer with with a 300W ps and an epox m/b. Same exact problem.
I tried calling the BFG tech support but all they could suggest is updating the bios on the MSI Neo which I did (I also spent 15 minutes arguing with the tech support lady that it's not a driver issue if it's happening at the bios screen. She insisted that it was a registry issue and did not understand the registry is for windows not bios).
I also reseated it many times as well as cleared the bios.
Am I missing anything ? Do you think it's a bad card ?
Thanks.
Gator
Thanks.
Gator
