Problem with audio
MoBsTa
I have these really old polk audio speakers, so they have an orange plug at the end that connects into the computer.
Problem is, theres no orange connector to my motherboard! So I plugged them into the green one and now they are not responding. Can someone help?
System specs:
Athlon 64 3200+ Venice
Thermaltake tsunami VA3000B case
ASUS A8V-E Deluxe mobo
nvidia geforce 6800GT
antec truepower 550w PSU
2GB of pqi turbo RAM 3-4-4-8 (1GBx2)
120GB of S-ATA Hard drive
did these come with an HP computer? I think those computers sound cards had built in amplifiers, i have a pair of polk speakers that used to hang on a pavilion mx90 monitor. When we switched to a newer hp the speakers didn't work anymore, because the sound signal coming from the new computer wasn't amplified, so we just went out and bought a new set of powered speakers. I'm sure you can find an in-line amplifier to drive these if you really want, but if there's nowhere to plug in any power or adjust the volume on the speakers themselves then they're probably passive and require some kind of amplification solution. Make sure a pair of headphones works in the green port just in case, but if they do then this is most likely the problem.
Yea lol they came with an hp computer I bought many years ago.
Ok then I guess I'll have to go out and buy new speakers
