Hey everyone. I recently decided to upgrade my computer, so I bought a 9800 pro and some ram, (which i bought PC133 instead of PC100, DOH! gota exchange it)
My current PC stats (stock compaq.. got for $60, don't laugh
900Mhz AMD Athlon Processor
128mb PC100 Ram
40 gig HDD
Ok now on to the problem:
I popped out my old video card and stuck the new one in, and hooked the male side of the cable onto an extension coming from the cable hooked to my CD rom, and the computer booted up fine. (There was female end cable also on the card.. do both need to be attached? I only had one cable end that would work). I put the driver CD in and began to install the drivers, when my screen went totally black, and a cursor started blinking in the top left corner. Ctrl+alt+delete, alt+tab, alt+F4... nothing worked, so I was forced to do a cold reboot. I checked the connections and everything seemed snug, so I tried again.. after about 2 minutes of the computer running, same thing happened. After about 2 more reboots I gave up. Any advice as to how I can fix this? Or even what is causing it?
Thanks in advance
//edit I hope I posted this in the right forum.. if not, mods feel free to move it
128mb PC100 Ram
40 gig HDD
Thanks in advance
