problem with Asus P5K Deluxe !!
truesq
hi every one
i just bought P5K deluxe from local store with Q6600
it was the only piece left and i think its old stock . cause it comes with Bios version 0202.
any way every thing was cool and running smoothly. until i decided to upgrade my bios
i upgrade it to the beta one 0505. and after that my PC is not booting any more.
so i unplugged the cable wait few mins then turn it on again and its working great .
but
if i change any thing in the bios even time it will not boot again and i have to unplug or clear cmos.
i tried to downgrade to 0404 or the old one 0202 but same thing .
so what do you think ?
shell i RMA ?
the guy told me they are getting P5K3 deluxe after 1 week . shell i pay more ?
and whats the different between deluxe and preimum ?
thanks alot ..........:)
P5K3 Deluxe is for use with DDR3 memory. I am unhappy with my P5K and I already wrote an e-mail to Newegg for returning this board. I flashed it to 404 bios and I got a lot more problems. RMA it, get your money back, and pick up something else. However I'm sure other people might tell you otherwise and label me as a flamebait. :mad:
Get the premium if you can.
There is something wrong with a lot of the P5K deluxe boards and Asus' way of fixing the problem is offering a new meaningless motherboard such as the premium instead of recalling the defective line of deluxe boards!
true i googled and found out alot of people facing exactly same my problem.
i guess i will wait until they arrange me the premium ..
thanks alot ..
im awaiting the arrival of my p5kdeluxe.
hopefully no problems. If so I just return and pick something else :p
too bad that a lot of ppl are having problems with the board.
because there are a lot of ppl having great success with the board.
No I agree with you. If flashing caused a bad BIOS (assuming you used the manufacture way to flashing), thats not your fault (unless you pulled the plug while it was flashing) and it should be ok to RMA and get another board.
My P5K Deluxe has been a great board and every flash has gone very well for me. Hopefully you can return it for a new one because it really is a great board.
My p5k deluxe board has been perfect for me. There has been no problems whatsoever. Sad that some people have trouble with it.
Same with mine, but my brother's has some serious SATA issues.
Sometimes the damn thing will restart normally, but most times, the SATA drives just go missing, or NTLDR cannot be found since the boot order changes by itself.
And lately, the PC will power off and it isn't even being overclocked!
