Problem with ASUS K8N-DL
Doufer
I am having trouble with an ASUS K8N-DL motherboard, and my 2 Opteron 242 processors.
We have mounted everything the way they should be, we have changed all components (like RAM and graphics card (XFX 6600 256MB PCI-X), but i dont get any image. The machine turns on, the coolers do function and the processores generate heat, etc. etc.
But the screen stays black, and nothing happens.
What could be the problem?
all that is needed to boot are the mb, cpu, memory, and graphics...obviously one is fried or is incompatible, or not seated correctly...
make sure you have the speaker hooked to the motherboard...it might give you a beep code that will identify your problem...
usually the problem with a no-boot situation is incompatible memory or a graphics card that isnt fully seated...unfortunately with the info provided nobody will be able to tell you anything more than that...
if the motherboard is in a case, it is possible it is shorted to the case somehow where it shouldn't be...
take the motherboard out and place it on the motherboard box and hook it to the powersupply...install you necessary components to boot and try it...make sure to connect the speaker as well for beep codes...
if nothing works then reset cmos and if you can test the components in another system...
it is pretty common for memory to be incompatible even though it should be and cause a no-boot situation...
you could also try just installed one processor to start...even though that shouldn't matter...
good luck man...sorry i cant help more :(
Sometimes you will need to boot the system with only one VC. Try the one closest to the CPUs.
