Problem with ASROCK K7S41GX
farscapesg1
OK, I am trying to put together a budget system for a coworker with the following
ASROCK K7S41GX motherboard
AMD Athlon XP 2500+
Muskin 512MB PC2700 (one stick)
Lite-on CDRW
Seagate 40 GB hard drive
Windows XP Home
Everything powers up fine, but I keep getting PAGE_FAULT_IN_NONPAGED_AREA errors when trying to install Windows. It's looking like an incompatibility problem with the memory, IMO, but I wanted to ask if anyone else has any ideas. I thought Mushkin was a good brand?
OK, the problem was definitely the RAM. I finally got the OS loaded and ran memtest and it gave me fail messages on the memory. I ran to Bestbuy and picked up a stick of KByte PC2700 and the system is up and running now :)
Thats good to hear. Did you check out the link I gave you? Honey X and Guni are a VERY good source for info on Asrock boards. They run them, and have 3rd party bios's for the boards, cool'n'quiet bios etc...
Later
MD
