Problem with Antec900 Power button?
the_slayer
Hi,
I have just setup the Antec900 and it seems to run fine. However occasinally i have had the issue where it doesnt respond to me pressing the power button? and i need to press it a few times to get it to turn on...
seems to be more successful if i hold it down for a bit longer... as apposed to a quick press
if it could be the connector at the top to the actual button being loose then how to get to that as from what i can see there is a metal panel in front of it...
gave the connector on the motherboard a bit of a wiggle and it hasnt done it since... but it seemed like it was in properly?
i am using the asus q-connect thing... which was fine in my old case... do ppl recommend not using them?
I've never had any problems with the q-connect, but it does sound like it could be a loose connection.
yeah i didnt have any probs when it was in my old box... could it be something loose at the button itself on the case? man i really dont wanna have to take the case back into the store and then have to rebuild the system!
