Problem with 2 windows installs! Need help
Deredox
I have a question,
I recently installed windows on my new SSD. I did this by using my dads computer with his NVME SSD still plugged into the motherboard.
I did the install on my SSD, shut off the pc and unplugged that same SSD. Now when i boot up his PC it keeps asking which Windows install i want to load, Volume 3 (his NVME SSD) or Volume 6 which is my new one but its not plugged in anymore.
How can i get rid of this? It slows down his boot times by 30 seconds.
Here is a picture of it:
Thank you for your help in advance!
You may want to see about a boot member fix if it thinks there are two instances of windows to boot from.
https://neosmart.net/wiki/fix-mbr/
This is usually avoided by installing windows with no other drives connected.
I have a question,
windows created a bootloader entry on his pc's drive. follow this to remove the new entry: https://winaero.com/change-default-os-boot-menu-windows-10/ then https://winaero.com/delete-boot-menu-entry-in-windows-10/#:~:text= To Delete Boot Menu Entry in Windows,/delete {identifier}. For example, bcdedit /delete... More
