Problem w/Audigy 2 ZS
KD_
Not sure if this belongs in Computer Audio or here, pls move if in wrong area.
Now to the problem, at x-mas I ordered the Audigy 2 ZS (waiting to ask til now b/c im getting new speakers). Installed it after I had just gotten everything else working. Disabled onboard sound hooked speakers up into the Audigy and got nothing. After a few hours of tinkering around could get 0 sound outta the Audigy.
This was all on a Abit NF7-S v2. Any help to get this card to work would be greatly appreciated, since its really just a waste for it to be sitting in the retail box on my dresser.
If you have it hooked up analog, then make sure "digital out" is not enabled (checked).
Do all of Creative's tests work out fine?
Is everything unmuted and at full volume (not that I suggest you leave it there)?
Do you have your speakers plugged into the right hole (third one from the firewire port)?
Have you tried it with anything else that plays sound (i.e. plugged a set of headphones in just to check if it's your speaker's problems).
