Hey,
Using VLC player, when streaming video over wireless network to a laptop, the stream starts to get choppy after about 10-15 seconds and video freezes up. This occurs to all type of video media, no matter the codec used.
- It works fine however over wired. I've changed all the settings of the wireless adapter to achieve max performance but the problem still occurs.
- Method to access the video files is simply from windows network drive.
-Network utilization when playing movies is usually between 1-10%, cpu goes to 70% max when streaming 720P, also RAM usage is about 70% , so I've already ruled out insufficient hardware.
The laptop runs windows vista, has a celeron M processor, 1 GB ram broadcom 802.11 g network adapter set to 54 mbps. The router also has the same bandwidth.
Anyone encounter this problem too? or can suggest a workaround?
