Problem seeing N network
Ihaveworms
Ukfay Ancerkay
I have a ASUS PCE-N13 card I am trying to connect to my N network. It is a Netgear WNDR3700 v2 running DD-WRT. It does not even show up in my list of networks, yet I see a neighbor's N network. I updated the drivers and I still do not see it. Here are my settings for the wireless:
If anyone can shed some light on this, it would be helpful.
Try changing your wireless network mode to N & G to see. You might even try to rename the SSID, save, and rescan.
Are you sure that your network is broadcasting? Do you have other PCs that can see your router?
Your network card has an operational frequency of 2.5GHz, and your Netgear is running on 5GHz. You need a Wireless N router that runs 2.4Ghz, or a card that can hit the 5GHz.
