problem... second harddrive disappeared
hey... my computer is acting shitty lately
first i plugged in the usb wire, the computer restarted itself
so i wait till it loads up again, but nothing is coming up
turned off the computer, cleaned out all the dusts, checked if everything is plugged and secured in
my bios recognizes all four of my drives, 80gb, 20gb, dvd rom, and cd burner
then it took a while to load... it was black for about 30 second or so, i heard clicking sounds...
then it showed the grey progress loading bar, after that it showed the winxp loading screen
it loaded windows fine... but then i go to my computer, no D: drive... i only see my primary harddrive, dvd and cd burner...
whats going on?
EDIT: removed my second harddrive, everything loaded normally... i guess my secondary harddrive died
rekojenasni_787 said:
......... i heard clicking sounds..........EDIT: removed my second harddrive, everything loaded normally... i guess my secondary harddrive died
yep :(
