Problem running Primie95
pOwErEd By NOS
Ok so I decided to run Prime95 on my computer for a bit about a week ago since UD was down. I noticed that eventhough my computer seemed pretty stable it wouldn't run Prime95 without erroring after a few mins. I was running my CPU at 2.25Ghz@1.65v. I lowered the CPU down to the stock 1.8Ghz at 1.525v (its what the BIOS told me stock is). Now it runs Prime95 perfectly for 8+ hours. My question is what could be causing my CPU to not run? My temps were 47-51C unter full load. Was I running to much volts or not enough?
Socket mobile 2400+ 45w
MSI VIA KT600 KT6V-LSR
512MBx2 Value RAM
ATI 9800pro
Mobile Bartons....hell...they can take 2.1+ volts if you have the proper cooling. I ran mine at 2.00 on air with a average cooler. Not recommending it, but it can be done with proper cooling tricks.
