Problem??? Random Shutdown only while gaming
Only in 3d.
I mostly play Americas Army but its also shutting down playing FEAR and Far Cry.
I am posting this in the Video Card area because its only happening in 3d... :mad:
Can I get some help trouble shooting this thing? Oh yeah, it just shuts off, no BSOD, nothing.
Also, all the fans are working and the proc temp is 42° while gaming
System specs below:
I think my main guess would be that your power supply isn't holding up when you are gaming. What are you using for a power supply?
My friend has this same exact problem. We have switched out the power supply/ram and done so many things. Nothing would help. He jsut decided to get a brand new conroe computer.
And he had a pretty nice Antec power supply (500 Watt)+ (i'm not sure the exact wattage)
Faulty surge protectors, outlets with faulty wiring, no grounds, or don't put out 12V, or the such is possible but not common. I have seen these happen before.
b4 u blame the PSU without any proof, underclock the GPU on your video card(use powerstrip or rivatuner) and c if solves the problem. if it does then its the video card, if not then u can start to blame other parts like PSU.
